Saltar al contenido principal
Ryobi CSB125 Trigger Replacement
Qué necesitas
  1. Ryobi CSB125 Trigger Replacement, Trigger: paso 1, imagen 1 de 1
    • Place the saw down on a flat surface with the motor facing up.
    • Make sure that the saw is unplugged from any power source.
  2. Ryobi CSB125 Trigger Replacement: paso 2, imagen 1 de 2 Ryobi CSB125 Trigger Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
  3. Ryobi CSB125 Trigger Replacement: paso 3, imagen 1 de 1
    • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
  4. Ryobi CSB125 Trigger Replacement: paso 4, imagen 1 de 1
    • Disconnect the two black wires by unscrewing them from the trigger switch using the Phillips #2 screwdriver.
  5. Ryobi CSB125 Trigger Replacement: paso 5, imagen 1 de 1
    • Remove the trigger from the saw.
    • You may have to use the wire strippers to the copper on the new plug.
    • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
Conclusión
3 personas más completaron esta guía.
Curtis Melo
Miembro Desde 10/31/19
1,066 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 512
