Introducción
This is a guide designed for replacing a broken direction switch in a RIDGID X4 18V Litium-Ion Impact Driver. This direction switch is imperative to the functionality of the driver. The direction switch determines whether the driver is going to rotate clockwise or counterclockwise.
Qué necesitas
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Remove the broken direction switch.
Replace the broken direction switch with a functional switch.
2 personas más completaron esta guía.
