Saltar al contenido principal
Retina MacBook 2015 Right Speaker Replacement
Qué necesitas
    • Before proceeding, unplug and power down your MacBook. Close the display and flip it upside-down.
    • 2015 models only: To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. Retina MacBook 2015 Right Speaker Replacement: paso 2, imagen 1 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 2, imagen 2 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 2, imagen 3 de 3
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  2. Retina MacBook 2015 Right Speaker Replacement: paso 3, imagen 1 de 1
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  3. Retina MacBook 2015 Right Speaker Replacement: paso 4, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 4, imagen 2 de 2
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
  4. Retina MacBook 2015 Right Speaker Replacement: paso 5, imagen 1 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 5, imagen 2 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 5, imagen 3 de 3
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
  5. Retina MacBook 2015 Right Speaker Replacement: paso 6, imagen 1 de 1
    • Close the MacBook and carefully flip it upside-down.
  6. Retina MacBook 2015 Right Speaker Replacement: paso 7, imagen 1 de 1
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  7. Retina MacBook 2015 Right Speaker Replacement: paso 8, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 8, imagen 2 de 2
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
  8. Retina MacBook 2015 Right Speaker Replacement: paso 9, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 9, imagen 2 de 2
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
  9. Retina MacBook 2015 Right Speaker Replacement: paso 10, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 10, imagen 2 de 2
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  10. Retina MacBook 2015 Right Speaker Replacement: paso 11, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 11, imagen 2 de 2
    • Carefully turn the MacBook over, so that the lower case lays flat.
    • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  11. Retina MacBook 2015 Right Speaker Replacement: paso 12, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 12, imagen 2 de 2
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
  12. Retina MacBook 2015 Right Speaker Replacement: paso 14, imagen 1 de 1
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Tri-point Y00 screw
    • Some variations of this model may use a Phillips screw.
    • 3.5 mm T5 Torx screw
  13. Retina MacBook 2015 Right Speaker Replacement: paso 15, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 15, imagen 2 de 2
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
  14. Retina MacBook 2015 Right Speaker Replacement: paso 16, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 16, imagen 2 de 2
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  15. Retina MacBook 2015 Right Speaker Replacement: paso 17, imagen 1 de 1
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
  16. Retina MacBook 2015 Right Speaker Replacement, Retina MacBook 2015 Lower Case Assembly Removal: paso 18, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement, Retina MacBook 2015 Lower Case Assembly Removal: paso 18, imagen 2 de 2
    • Use tweezers to peel back the tape covering the display cable connector.
  17. Retina MacBook 2015 Right Speaker Replacement: paso 19, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 19, imagen 2 de 2
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
  18. Retina MacBook 2015 Right Speaker Replacement: paso 20, imagen 1 de 1
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If it doesn't separate easily, heat the cable and/or the case directly beneath it with a hair dryer or iOpener to soften the adhesive, and try again.
  19. Retina MacBook 2015 Right Speaker Replacement: paso 22, imagen 1 de 1
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap.
    • The flap must remain closed when the cable is reinserted during reassembly. Carefully line up the cable with the gold contacts facing down, and gently slide it into the connector. Take care not to crimp or damage the cable. When fully inserted, the indentations on the sides should not be visible.
  20. Retina MacBook 2015 Right Speaker Replacement: paso 23, imagen 1 de 1
    • Separate the upper case assembly from the lower case assembly.
  21. Retina MacBook 2015 Right Speaker Replacement, Logic Board: paso 24, imagen 1 de 3 Retina MacBook 2015 Right Speaker Replacement, Logic Board: paso 24, imagen 2 de 3 Retina MacBook 2015 Right Speaker Replacement, Logic Board: paso 24, imagen 3 de 3
    • Use tweezers to peel up the tape covering the two ZIF connectors—one for the right speaker cable, and one for the audio jack board cable.
  22. Retina MacBook 2015 Right Speaker Replacement: paso 25, imagen 1 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 25, imagen 2 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 25, imagen 3 de 3
    • Use the point of a spudger to flip up both ZIF connector retaining flaps.
  23. Retina MacBook 2015 Right Speaker Replacement: paso 26, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 26, imagen 2 de 2
    • Carefully pull straight back on the two pieces of tape you just peeled up to disconnect the two ribbon cables.
  24. Retina MacBook 2015 Right Speaker Replacement: paso 27, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 27, imagen 2 de 2
    • Use the point of a spudger to peel up the foam pad covering the two antenna connectors.
  25. Retina MacBook 2015 Right Speaker Replacement: paso 28, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 28, imagen 2 de 2
    • Use tweezers to disconnect the first antenna connector by lifting it straight up from its socket.
    • The antenna connectors and sockets are extremely fragile. Be very careful to lift only on the connector, and not on the socket itself. Do not lift under the cable, or put any unnecessary strain on it.
  26. Retina MacBook 2015 Right Speaker Replacement: paso 29, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 29, imagen 2 de 2
    • Use tweezers to disconnect the second antenna connector by lifting it straight up from its socket.
  27. Retina MacBook 2015 Right Speaker Replacement: paso 30, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 30, imagen 2 de 2
    • Use a spudger to disconnect the left speaker cable connector by prying it straight up from the logic board.
  28. Retina MacBook 2015 Right Speaker Replacement: paso 31, imagen 1 de 2 Retina MacBook 2015 Right Speaker Replacement: paso 31, imagen 2 de 2
    • Use a spudger to flip up the retaining flap on the trackpad cable ZIF connector.
  29. Retina MacBook 2015 Right Speaker Replacement: paso 32, imagen 1 de 1
    • Disconnect the trackpad cable from the logic board by gently pulling it straight out of its connector.
  30. Retina MacBook 2015 Right Speaker Replacement: paso 33, imagen 1 de 1
    • Remove the single 3.5 mm T5 Torx screw securing the logic board to the lower case.
  31. Retina MacBook 2015 Right Speaker Replacement: paso 34, imagen 1 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 34, imagen 2 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 34, imagen 3 de 3
    • Flip up the front edge of the logic board.
    • Handle the logic board only by its edges.
    • Lift and detach the EMI tape securing the logic board to the lower case.
    • Warming the tape with a hair dryer or iOpener makes it easier to detach.
    • Reattach the tape securely during reassembly.
  32. Retina MacBook 2015 Right Speaker Replacement: paso 35, imagen 1 de 1
    • Remove the logic board.
  33. Retina MacBook 2015 Right Speaker Replacement, Right Speaker: paso 36, imagen 1 de 1
    • Using tweezers, remove the foam pad covering the screw on the left side of the right speaker.
    • If you pull on the foam portion, it will tear. Try to get your tweezers under the adhesive pad holding the foam to the top of the screw.
  34. Retina MacBook 2015 Right Speaker Replacement: paso 37, imagen 1 de 1
    • Remove the two 4.1 mm T3 Torx screws securing the right speaker.
  35. Retina MacBook 2015 Right Speaker Replacement: paso 38, imagen 1 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 38, imagen 2 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 38, imagen 3 de 3
    • Using tweezers, carefully peel up the tape securing the right antenna cable to the lower case.
  36. Retina MacBook 2015 Right Speaker Replacement: paso 39, imagen 1 de 1
    • Prepare an iOpener and heat the lower case directly beneath the right speaker for 1-2 minutes, in order to soften up the adhesive securing the speaker.
  37. Retina MacBook 2015 Right Speaker Replacement: paso 40, imagen 1 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 40, imagen 2 de 3 Retina MacBook 2015 Right Speaker Replacement: paso 40, imagen 3 de 3
    • Use a plastic opening tool to pry under the top edge of the right speaker, and separate it from the lower case.
  38. Retina MacBook 2015 Right Speaker Replacement: paso 41, imagen 1 de 1
    • Remove the right speaker.
Conclusión
To reassemble your device, follow these instructions in reverse order. To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
Una persona más ha completado esta guía.
Geoff Wacker
Miembro Desde 09/30/13
87,916 Reputación
89 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 62
Todo El Tiempo: 10,085
