Introducción
The Palm m105 is a personal digital assistant that can be a useful tool. The palm can experience slowdowns and freezes. The easiest way to fix this problem is to reset the Palm. Resets are easy to perform and will take no time. There are two types of reset a soft reset and a hard reset. A soft reset will solve most problems. If the problem persists after a soft reset proceed with a hard reset.
Herramientas
Partes
No se especificaron partes.
To soft reset the device, use a paperclip to carefully press the reset button located on the back of the device. The exact location of the button can be seen in the picture.
After you press the button, the device will reboot as if you just powered on your device and it should clear up most common device problems.
If your device is still not powering up or has a blank display, the next step will help you perform a hard reset of the device.
