Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
To soft reset the device, use a paperclip to carefully press the reset button located on the back of the device. The exact location of the button can be seen in the picture.
  • To soft reset the device, use a paperclip to carefully press the reset button located on the back of the device. The exact location of the button can be seen in the picture.
  • A soft reset means that it will usually not affect your personal data on your device, unless the batteries are low.
  • After you press the button, the device will reboot as if you just powered on your device and it should clear up most common device problems.
  • If your device is still not powering up or has a blank display, the next step will help you perform a hard reset of the device.
Insertar traducción aquí
