Saltar al contenido principal
Repairing Black Display on an Asus Transformer TF101
Qué necesitas
  1. Repairing Black Display on an Asus Transformer TF101, Bezel: paso 1, imagen 1 de 2 Repairing Black Display on an Asus Transformer TF101, Bezel: paso 1, imagen 2 de 2
    • The first step is to remove two Small Torx Screws on the bottom. I don't know the size as I happened to have an unmarked Torx screwdriver nearby that happened to fit.
  2. Repairing Black Display on an Asus Transformer TF101: paso 2, imagen 1 de 2 Repairing Black Display on an Asus Transformer TF101: paso 2, imagen 2 de 2
    • I used a metal opening tool to spearate the bezel from the front of the unit. Once I had it separated in one area it was relatively easy to spread it using my fingertip. I then worked around the bezel until it popped off.
  3. Repairing Black Display on an Asus Transformer TF101: paso 3, imagen 1 de 1
    • There are four screws to remove behind the bezel. I never got a good picture of the screws but two are indicated here and the other two are in a similar location but just out of the picture.
Conclusión
14 personas más completaron esta guía.
Rene Jeddore
Miembro Desde 10/23/12
1,360 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 23
Todo El Tiempo: 8,833
