Saltar al contenido principal
Repair a Hole in Patagonia Waders
Qué necesitas
  1. Repair a Hole in Patagonia Waders, Testing Patagonia Waders For Leaks: paso 1, imagen 1 de 3 Repair a Hole in Patagonia Waders, Testing Patagonia Waders For Leaks: paso 1, imagen 2 de 3 Repair a Hole in Patagonia Waders, Testing Patagonia Waders For Leaks: paso 1, imagen 3 de 3
    • Set up a ladder in a level place outside that you don't mind getting wet.
    • Turn the waders inside out.
    • Clip the waders to the ladder.
  2. Repair a Hole in Patagonia Waders: paso 2, imagen 1 de 3 Repair a Hole in Patagonia Waders: paso 2, imagen 2 de 3 Repair a Hole in Patagonia Waders: paso 2, imagen 3 de 3
    • Put the hose into the waders.
    • Slide the hose into one leg of the waders.
  3. Repair a Hole in Patagonia Waders: paso 3, imagen 1 de 2 Repair a Hole in Patagonia Waders: paso 3, imagen 2 de 2
    • Turn on the hose and begin to fill the waders.
    • Be sure to pay attention because the large amount of water may tip the ladder. If needed, weigh the back side of the ladder down to prevent it from tipping.
  4. Repair a Hole in Patagonia Waders: paso 4, imagen 1 de 3 Repair a Hole in Patagonia Waders: paso 4, imagen 2 de 3 Repair a Hole in Patagonia Waders: paso 4, imagen 3 de 3
    • Watch for leaks. When you find a leak, mark it with a permanent marker.
    • Repeat this process for the other leg, marking all the leaks you find.
    • Dump the water out and allow the waders to dry completely before you continue.
  5. Repair a Hole in Patagonia Waders, Repair a Hole in Patagonia Waders: paso 5, imagen 1 de 3 Repair a Hole in Patagonia Waders, Repair a Hole in Patagonia Waders: paso 5, imagen 2 de 3 Repair a Hole in Patagonia Waders, Repair a Hole in Patagonia Waders: paso 5, imagen 3 de 3
    • Wipe your marked areas down with an alcohol wipe to clean them.
    • Wait for the area to completely dry before continuing.
  6. Repair a Hole in Patagonia Waders: paso 6, imagen 1 de 1
    • Add a drop of Seam Grip to the marked area.
    • You need enough Seam Grip to thinly cover a one-inch square.
  7. Repair a Hole in Patagonia Waders: paso 7, imagen 1 de 2 Repair a Hole in Patagonia Waders: paso 7, imagen 2 de 2
    • Use the paintbrush to spread the Seam Grip thinly and evenly over the area.
  8. Repair a Hole in Patagonia Waders: paso 8, imagen 1 de 2 Repair a Hole in Patagonia Waders: paso 8, imagen 2 de 2
    • Rotate your brush 90 degrees and spread the glue evenly over the area.
  9. Repair a Hole in Patagonia Waders: paso 9, imagen 1 de 3 Repair a Hole in Patagonia Waders: paso 9, imagen 2 de 3 Repair a Hole in Patagonia Waders: paso 9, imagen 3 de 3
    • Apply the thin film (included in your wader repair kit) on top of the Seam Grip.
    • Smooth out the film with your finger, pushing out any air bubbles.
    • Allow the waders to sit undisturbed for 12 hours.
  10. Repair a Hole in Patagonia Waders: paso 10, imagen 1 de 3 Repair a Hole in Patagonia Waders: paso 10, imagen 2 de 3 Repair a Hole in Patagonia Waders: paso 10, imagen 3 de 3
    • Peel the thin film off of the waders.
Conclusión
You should now have an invisible, but watertight patch. Repeat this for all of the leaks you marked.
8 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
88,605 Reputación
132 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
136 Miembros
15,157 Guías creadas
2 comentarios
Ho riparato i wader seguendo le indicazioni, ed e stato un trionfo, lavoro perfettamente riuscito. Ora devo provare la tenuta andando a pescare.
Unico problema e il pennarello, che bagnandosi con l’acqua sbava e tende a cancellarsi pur essendo indelebile…. Quando si i Wader si asciugano si rischia di non vedere bene i buchi da riparare se sono di piccola entità.
loris vitali - Contestar
My waders have a nice, round hole about 1/4" in diameter, an inch above the top of the gravel guard. Since Seam Grip can't be applied where there isn't any fabric, a patch is evidently needed, but what to use? LDPE? Tenacious Tape? Other? This is a recent pair of Swiftcurrent waders.
AMG - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 75
Ultimos 30 días: 340
Todo El Tiempo: 15,935
