Saltar al contenido principal
Removinging Panasonic DVD-RV31 Player Rear Panel
Qué necesitas
  1. Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: paso 1, imagen 1 de 2 Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: paso 1, imagen 2 de 2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  2. Removinging Panasonic DVD-RV31 Player Rear Panel: paso 2, imagen 1 de 1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  3. Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: paso 3, imagen 1 de 2 Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: paso 3, imagen 2 de 2
    • Be sure case cover has been removed prior to back panel removal.
    • Remove 5 screws from panel, as shown.
  4. Removinging Panasonic DVD-RV31 Player Rear Panel: paso 4, imagen 1 de 2 Removinging Panasonic DVD-RV31 Player Rear Panel: paso 4, imagen 2 de 2
    • Use flat-head screwdriver to push in square tabs, located on each side of the back panel.
    • Use caution, the edges are sharp.
Conclusión
Una persona más ha completado esta guía.
Kevin
Miembro Desde 04/26/11
375 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 18-20, Garner Spring 2011 Miembro de Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 2,285
