Saltar al contenido principal
Removing the Samsung LA40R81BD 40in LCD TV Main Board
Qué necesitas
  1. Removing the Samsung LA40R81BD 40in LCD TV Main Board, Rear Cover: paso 1, imagen 1 de 1
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
  2. Removing the Samsung LA40R81BD 40in LCD TV Main Board, Removing the Samsung LA40R81BD 40in LCD TV Main Board: paso 2, imagen 1 de 1
    • Gently peel away the conductive fabric from the metal cover on the board
    • Remove 5 connectors from the board
    • Remove 6 screws from the perimeter of the board.
    • Lift the main board away from the chassis ensuring you don's snag or catch any of the cables.
Conclusión
12 personas más completaron esta guía.
Richdave
Miembro Desde 04/09/10
32,371 Reputación
30 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
Miembros de 327
1,699 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 44
Todo El Tiempo: 5,755
