Introducción
This procedure is not for the faint of heart. It is very difficult, and can be dangerous if you are not careful and properly equipped. Read the entire procedure before you begin to be sure you're up to the task.
This guide is intended as a generic supplement guide, and should be followed alongside the standard front panel replacement guide for any iPad or iPad Mini.
Herramientas
Partes
No se especificaron partes.
Resumen del Video
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. For particularly bad breaks, you may need to lay down two layers.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Use your hot iOpener to heat up all four edges of the front panel. Let the iOpener rest on each edge for at least 90 seconds, microwaving for 30 seconds at a time as needed.
Once all of the adhesive is warmed, pick out the edge with the largest uncracked section of glass.
To protect your iOpener from the glass and keep it from filling with glass dust, stick some masking tape to one side.
Heat the iOpener and apply it to one edge of the iPad, directly on top of the pieces of glass that are still adhered to the rear case of the iPad.
Leave the iOpener there for at least 90 seconds, to soften the adhesive holding these small pieces in place.
16 personas más completaron esta guía.
