Saltar al contenido principal
Remington MB4040 Thermal Switch Replacement
Qué necesitas
  1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: paso 1, imagen 1 de 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: paso 1, imagen 2 de 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: paso 1, imagen 3 de 3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: paso 2, imagen 1 de 2 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: paso 2, imagen 2 de 2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: paso 3, imagen 1 de 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: paso 3, imagen 2 de 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: paso 3, imagen 3 de 3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): paso 4, imagen 1 de 2 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): paso 4, imagen 2 de 2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: paso 5, imagen 1 de 2 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: paso 5, imagen 2 de 2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: paso 6, imagen 1 de 2 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: paso 6, imagen 2 de 2
  7. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: paso 7, imagen 1 de 1
    • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
    • Use a low temperature RTV to readhere the thermal switch to the battery.
    • Remove the soldering holding the thermal switch to the motherboard.
Conclusión
3 personas más completaron esta guía.
Cameron Carnahan
Miembro Desde 01/20/15
1,067 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 1-5, Blackwell Winter 2015 Miembro de USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 2,852
