Introducción
Si tu oneplus 5t tiene un puerto de carga o un conector para auriculares rotos, puedes seguir este video para reemplazar la pieza rota. Este video te muestra el procedimiento de reemplazo paso a paso.
Nota: abre el dispositivo en el inferior de los dos bordes en el lado de los dispositivos. El uso del borde superior quita el vidrio de la pantalla y puede provocar que se rompa el vidrio.
Qué necesitas
Instrucciones de Vídeo
Para volver a montar tu dispositivo, sigue estas instrucciones en orden inverso.
15 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
7Guía Comentarios
Thanks a lot for the guide! This was my first time taking apart a phone and while it wasn’t as easy as it looked, it wasn’t all too bad either and I’m super happy that I’ve done it! :D
I’ve made the mistake to buy only one plastic spudger because it looked pretty easy in the video but it got used up for me quickly so, for anyone else who is thinking about doing this without much experience, you will want a couple of those just to be safe.
Luckily I’ve had some guitar picks laying around which were able to do the job fairly well too but they didn’t quite get under the screen like the spudger did at first.
Balazs Both - Contestar Compartir
for me the bottom screws where not a T2 torx for me, I bought multiple ones from ifixit but they don't fit. will try to buy an T1 torx screw driver if i can find one. thanks for the nice repair guide though.
Jason Mensingh - Contestar Compartir
I cracked the screen as i tried to open the phone, even carefully :/ The thing is that i removed only the screen and not the total part of the phone from the cover :/
Vivien Meublat - Contestar Compartir
thanks a lot for the tutorial. Worked as a charm for me. Had to start from the side to open it, then down to the charging port and to the other side.
use philips 00 & torx 2.
Przemek Grela - Contestar Compartir
The company website is a treasure trove of information and services. It's a go-to hub for all academic needs, offering reliability and expertise. Trust the company website for comprehensive academic support.
MolliePaxton - Contestar Compartir
