Introducción
Esta guía se utiliza para reemplazar la tapa trasera del dispositivo o como una precursora para acceder los componentes internos del dispositivo.
Qué necesitas
Apaga el dispositivo.
Usa tu herramienta de apertura de plástico para calzar entre los rebordes alrededor de los lados del dispositivo. Haz palanca en cada lado, uno a la vez.
Para volver a ensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
16 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
83%
¡ Mariana Roca nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
4 comentarios
Step left out. ifixit.com video on Youtube show use of craft knife as first step to get into very tight case fitting, then the use of plastic pry tool to go around releasing the backcover.
I didnt read the comment about it being tight and using a knife, until I had damaged the prying tools :-(
How do u take off the cover do u have to have that tool
I had very little problem prying of the back of my nexus 7 2012. Once you get the first corner done, the rest comes pretty easy.
I ended up using an old hotel keycard as a spudger and it worked fine.
I needed access to the cables that connect the touchscreen to the motherboard so that my touch screen would respond.
Worked like a charm!
