Introducción
Quitar la memoria RAM es una tarea fácil ya que no requiere de ninguna herramienta
Qué necesitas
Posiciona tus dedos en las depresiones marcadas en la cubierta inferior.
Rota la cubierta inferior en sentido contrario a las agujas del reloj hasta el el punto blanco pintado en la parte inferior esté alineado con el anillo inscripto en la carcasa exterior.
Suelte las pestañas de cada lado del chip RAM empujando simultáneamente cada pestaña hacia afuera del chip.
Una vez que el chip RAM haya salido, sáquelo de su zócalo.
Para remontar tu dispositivo, sigue las instrucciones al revés
184 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Iker NH nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
7Guía Comentarios
So if I were to replace the Ram on my mac mini I would only have the option to choose between the 2 gb chip or the 4gb chip? I know dumb question lol.
2x8GB is as much as those motherboards can handle.
Dear everyone,
Does this mac mini accept :
KINGSTON DDR3 PC3-12800 - 2 x 4 Go (8 Go) 1600 MHZ - CAS 10 - HyperX Fury Black Series
Thank you.
I always consult Crucial's memory configuration tool. For a late-2012 Mac mini, see http://www.crucial.com/usa/en/compatible....
According to them, this Mac can go up to 16GB (2 SO-DIMMs of 8GB each). The SO-DIMMs should be DDRL3L-1600 (DDR3L PC3L-12800, CL=11, unbuffered, non-ECC, DDR3L-1600, 1.35v)
The SO-DIMMs you mentioned seem like they should be compatible (CL=10 should work fine in a computer that can accept CL=11). But I would only buy from a vendor that has a compatibility guarantee. If there's a problem, I would want to be able to return them for a refund.
The SODIMMs don't need to be low voltage DDR3L (i.e. 1.35 volt). In fact Apple recommends (https://support.apple.com/en-gb/HT202593) regular 1.5 volt DDR3 and most late 2012 Mac Minis were shipped with it. So is Crucial wrong? The truth is that either will work.
