Saltar al contenido principal
Razer Viper Mini Trigger Switches Replacement
Qué necesitas
  1. Razer Viper Mini Trigger Switches Replacement, Remove Information Sticker: paso 1, imagen 1 de 2 Razer Viper Mini Trigger Switches Replacement, Remove Information Sticker: paso 1, imagen 2 de 2
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Make sure to unplug the mouse before doing anything.
    • Turn the Mouse Over so the bottom is facing up.
    • Remember to take a photo of your serial number or write it down
    • Take off the information sticker and the plastic cover from the bottom of the mouse.
  2. Razer Viper Mini Trigger Switches Replacement, Remove Baseplate Screws: paso 2, imagen 1 de 2 Razer Viper Mini Trigger Switches Replacement, Remove Baseplate Screws: paso 2, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the three 2 mm screws from the bottom of the mouse.
    • When removing the screws, unscrew them each slightly and consecutively until you can pull them out with your hands.
  3. Razer Viper Mini Trigger Switches Replacement, Detach backplate: paso 3, imagen 1 de 3 Razer Viper Mini Trigger Switches Replacement, Detach backplate: paso 3, imagen 2 de 3 Razer Viper Mini Trigger Switches Replacement, Detach backplate: paso 3, imagen 3 de 3
    • Use the plastic spudger to gently lift the backplate from the mouse shell.
    • Insert the spudger into the bottom back of the mouse and slowly move it around the mouse to release the backplate.
    • Do not try to push or jab the mouse with the plastic spudger with a large amount of force, this can damage the plating of your mouse.
  4. Razer Viper Mini Trigger Switches Replacement, Remove shell: paso 4, imagen 1 de 2 Razer Viper Mini Trigger Switches Replacement, Remove shell: paso 4, imagen 2 de 2
    • Use the plastic spudger once again to remove the top shell of the mouse.
    • It is similar to the previous step, as you have to pry the plastic spudger gently into the bottom of the mouse and move it slowly inwards and upwards to release the shell.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the cable.
  5. Razer Viper Mini Trigger Switches Replacement, Disconnect the Ribbon Connector: paso 5, imagen 1 de 2 Razer Viper Mini Trigger Switches Replacement, Disconnect the Ribbon Connector: paso 5, imagen 2 de 2
    • Disconnect the ribbon connector between the motherboard and the USB cable by squeezing the connector and pulling up.
    • Pulling too hard could damage the wire connections.
    • Pulling by the ribbon instead of the connector can dislocate the wires.
  6. Razer Viper Mini Trigger Switches Replacement, Unscrew Motherboard from Case: paso 6, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove 2 5.5 and 3 2.5 mm screws.
  7. Razer Viper Mini Trigger Switches Replacement, Remove Motherboard: paso 7, imagen 1 de 1
    • Remove the motherboard by grasping the sides and gently pulling upward.
  8. Razer Viper Mini Trigger Switches Replacement, Remove Left Switch: paso 8, imagen 1 de 2 Razer Viper Mini Trigger Switches Replacement, Remove Left Switch: paso 8, imagen 2 de 2
    • Press the connectors upwards to remove the left switch from the PCB.
  9. Razer Viper Mini Trigger Switches Replacement, Remove Right Switch: paso 9, imagen 1 de 2 Razer Viper Mini Trigger Switches Replacement, Remove Right Switch: paso 9, imagen 2 de 2
    • Press the connectors upwards to remove the Right switch from the PCB.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 22
Ultimos 30 días: 76
Todo El Tiempo: 2,139
