Saltar al contenido principal
Razer Blade Stealth 2017 Battery Replacement
Qué necesitas
  1. Razer Blade Stealth 2017 Battery Replacement, Battery: paso 1, imagen 1 de 2 Razer Blade Stealth 2017 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Battery Replacement: paso 3, imagen 1 de 2 Razer Blade Stealth 2017 Battery Replacement: paso 3, imagen 2 de 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Battery Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Battery Replacement: paso 5, imagen 1 de 2 Razer Blade Stealth 2017 Battery Replacement: paso 5, imagen 2 de 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
16 personas más completaron esta guía.
Equipo
Cal Poly, Team S11-G3, Regan Fall 2019 Miembro de Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
Miembros de 4
7 Guías creadas
2 comentarios
ive done everything correctly and laptop boots up but now I have no battery percentage information. any solutions on how to fix?
fdf - Contestar
Where did you get the replacement battery? The replacement we purchased for two Razer units about a year ago worked fine, but a replacement battery purchased online about a month and a half ago from Amazon is showing the same issue. Essentially, it's not detected by the operating system at all, or only very rarely. Looks like a bad batch of batteries from wherever these sellers are getting their supply.
DST - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 70
Todo El Tiempo: 18,005
