Saltar al contenido principal
Razer Blade 15" (2020) Back Cover Replacement
Qué necesitas
  1. Razer Blade 15" (2020) Back Cover Replacement, Unfasten the back cover: paso 1, imagen 1 de 1
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  2. Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: paso 2, imagen 1 de 3 Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: paso 2, imagen 2 de 3 Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: paso 2, imagen 3 de 3
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  3. Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: paso 3, imagen 1 de 3 Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: paso 3, imagen 2 de 3 Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: paso 3, imagen 3 de 3
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
Conclusión
Clay Eickemeyer
Miembro Desde 09/19/22
81,913 Reputación
455 Guías creadas
Equipo
Guide Team Miembro de Guide Team
Staff
Miembros de 9
11,426 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 24
Todo El Tiempo: 528
