Qué necesitas
Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
Use the flat end of the spudger to pop-out the scroll wheel assembly.
Remove six 4 mm screws using a JIS #0 screwdriver.
Insert the flat end of a spudger in the gap between the motherboard and the rest of the mouse.
Slowly pry up the edge of the board, moving around the mouse slowly in a counterclockwise direction.
