Saltar al contenido principal
RIDGID R84015 X2 Speed Switch Replacement
Qué necesitas
  1. RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: paso 1, imagen 1 de 2 RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: paso 1, imagen 2 de 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Speed Switch Replacement: paso 2, imagen 1 de 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Speed Switch Replacement: paso 3, imagen 1 de 2 RIDGID R84015 X2 Speed Switch Replacement: paso 3, imagen 2 de 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Speed Switch Replacement, Speed Switch: paso 4, imagen 1 de 1
    • Locate small metal bar above plastic part of drill.
    • Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
  5. RIDGID R84015 X2 Speed Switch Replacement: paso 5, imagen 1 de 2 RIDGID R84015 X2 Speed Switch Replacement: paso 5, imagen 2 de 2
    • If the bar moves, next check the small plastic switch that is numbered 1 and 2.
    • Make sure the small tabs on the underside of the switch that move the bar are intact.
    • Replace switch as needed.
Conclusión
2 personas más completaron esta guía.
Evan Long
Miembro Desde 04/15/10
262 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 15-48, Garner Spring 2010 Miembro de Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 3,639
