Saltar al contenido principal
Protocol Kaptur GPS Main Circuit Board Replacement
Qué necesitas
  1. Protocol Kaptur GPS Main Circuit Board Replacement, Battery: paso 1, imagen 1 de 2 Protocol Kaptur GPS Main Circuit Board Replacement, Battery: paso 1, imagen 2 de 2
    • The battery is accessible through the back of the drone.
    • Press the tabs on both sides of the white stripe to pull the battery out.
  2. Protocol Kaptur GPS Main Circuit Board Replacement: paso 2, imagen 1 de 3 Protocol Kaptur GPS Main Circuit Board Replacement: paso 2, imagen 2 de 3 Protocol Kaptur GPS Main Circuit Board Replacement: paso 2, imagen 3 de 3
    • Remove the screws starting with the three smaller ones on the top part of the battery.
    • Remove the three screws on the other side.
    • There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
    • There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws.
  3. Protocol Kaptur GPS Main Circuit Board Replacement: paso 3, imagen 1 de 2 Protocol Kaptur GPS Main Circuit Board Replacement: paso 3, imagen 2 de 2
    • Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
  4. Protocol Kaptur GPS Main Circuit Board Replacement: paso 4, imagen 1 de 2 Protocol Kaptur GPS Main Circuit Board Replacement: paso 4, imagen 2 de 2
    • The battery is now removable from its container.
    • During reassembly, make sure the outlet is returned to its holder and faces the correct direction.
  5. Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: paso 5, imagen 1 de 2 Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: paso 5, imagen 2 de 2
    • Remove the 4x 7mm screws on the top and bottom, and the 2x 5mm screws from the middle, then remove the back part of the housing.
    • Remove the two hidden screws at the bottom, and the white power button.
    • There will be 6x 7 mm Phillips head screws, and 2x 5 mm Phillips head screws.
  6. Protocol Kaptur GPS Main Circuit Board Replacement: paso 6, imagen 1 de 3 Protocol Kaptur GPS Main Circuit Board Replacement: paso 6, imagen 2 de 3 Protocol Kaptur GPS Main Circuit Board Replacement: paso 6, imagen 3 de 3
    • Unplug all the cords from the circuit boards.
    • Carefully slide the main body right off the arms.
  7. Protocol Kaptur GPS Main Circuit Board Replacement: paso 7, imagen 1 de 2 Protocol Kaptur GPS Main Circuit Board Replacement: paso 7, imagen 2 de 2
    • Remove the four 4mm Phillips screws.
    • Desolder all cords on the circuit board, and pull the board up and out.
    • It is important to keep track of where the leads came from. Red/Blue and Black/White pairings belong to motors, whereas Black/Red pairings belong to lights. The ports are labeled on the board.
Conclusión
Una persona más ha completado esta guía.
Connor Woitte
Miembro Desde 02/15/18
858 Reputación
3 Guías creadas
Equipo
UW Stout, Team S8-G6, Ogden Spring 2018 Miembro de UW Stout, Team S8-G6, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G6
Miembros de 3
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 818
