Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 2
Now that the battery is out, remove the screws starting with the four smaller ones on the top part of the battery. After this, remove the last four on the side. Make sure to keep track of where each screw came from. There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws. There is another screw that is located where the arrow is pointed. You will need to take the other screws out first before you can get to this one.
  • Now that the battery is out, remove the screws starting with the four smaller ones on the top part of the battery. After this, remove the last four on the side. Make sure to keep track of where each screw came from.
  • There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws.
  • There is another screw that is located where the arrow is pointed. You will need to take the other screws out first before you can get to this one.
Insertar traducción aquí
