Saltar al contenido principal
PowerBook G4 Titanium Mercury Hard Drive Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
  1. PowerBook G4 Titanium Mercury Hard Drive Replacement: paso 2, imagen 1 de 1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  2. PowerBook G4 Titanium Mercury Hard Drive Replacement: paso 3, imagen 1 de 1
    • Your laptop should look approximately like this.
  3. PowerBook G4 Titanium Mercury Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
  4. PowerBook G4 Titanium Mercury Hard Drive Replacement: paso 5, imagen 1 de 1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  5. PowerBook G4 Titanium Mercury Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  6. PowerBook G4 Titanium Mercury Hard Drive Replacement: paso 7, imagen 1 de 1
Conclusión
7 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 9,953
