Introducción
Tripped over your power cord? Well, at least you don't have to replace the entire logic board.
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
Lift the heat shield up and pull it toward you.
Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
Pull the battery cable directly up from the logic board.
Remove the battery from its holder by pulling up and to the left.
Remove the long silver Phillips #1 screw from the heat sink.
Remove the two T8 Torx screws that attach the heat sink to the processor.
Grasp the plastic tab on the processor's right side and pull it directly up.
Remove the black Torx screw from the right side of the modem.
Remove the small black plastic rectangle with four holes.
Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
Push the display back so that it lies flat.
Slip your index finger or a nylon tool under the clutch cover near the power button and pull gently upward until you feel it come free.
Repeat the previous step on the left side.
Grasp the orange display data cable and disconnect it from the logic board.
Turn the laptop around so that its back faces you.
Open the port door located at the back of the laptop.
Remove the four black Torx screws.
Disconnect the wide orange cable that connects the airport card slot to the logic board.
Remove the two long silver Torx screws from the power card in the center of the laptop
Gently clasp the left side of the metal shield between your thumb and forefinger and carefully pull up and toward the front of the laptop.
Remove the single short black Torx screw anchoring the metal framework to the lower casing.
Use needle-nose pliers or a five millimeter nut driver to remove the small metal nut from the bolt.
5 personas más completaron esta guía.
Documentos Adjuntos
2 comentarios
I recently was trying to replace the hard drive in my Pismo, but didn't unplug the computer. I didn't realize this until after I'd taken out the hard drive. The result was that the computer would not start. The hard drive wouldn't start spinning, there was no startup chime. I replaced the sound card and now it boots and runs fine.
