Saltar al contenido principal
PowerBook G3 Lombard Processor Replacement
Qué necesitas
  1. PowerBook G3 Lombard Processor Replacement, Keyboard: paso 1, imagen 1 de 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Processor Replacement: paso 2, imagen 1 de 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Processor Replacement: paso 3, imagen 1 de 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Processor Replacement, Heat Shield: paso 4, imagen 1 de 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Processor Replacement: paso 5, imagen 1 de 1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Processor Replacement: paso 6, imagen 1 de 1
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard Processor Replacement, PRAM Battery: paso 7, imagen 1 de 1
    • Pull the battery cable directly up from the logic board.
  8. PowerBook G3 Lombard Processor Replacement: paso 8, imagen 1 de 1
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Lombard Processor Replacement, Modem: paso 9, imagen 1 de 1
    • Remove the two silver Phillips screws from the modem.
  10. PowerBook G3 Lombard Processor Replacement: paso 10, imagen 1 de 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. PowerBook G3 Lombard Processor Replacement: paso 11, imagen 1 de 1
    • Disconnect the cable from the right side of the modem.
  12. PowerBook G3 Lombard Processor Replacement: paso 12, imagen 1 de 1
  13. PowerBook G3 Lombard Processor Replacement, Processor: paso 13, imagen 1 de 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  14. PowerBook G3 Lombard Processor Replacement: paso 14, imagen 1 de 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  15. PowerBook G3 Lombard Processor Replacement: paso 15, imagen 1 de 1
Conclusión
5 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 5,880
