Saltar al contenido principal
PowerBook G3 Lombard Heat Shield Replacement
Qué necesitas
  1. PowerBook G3 Lombard Heat Shield Replacement, Keyboard: paso 1, imagen 1 de 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Heat Shield Replacement: paso 2, imagen 1 de 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Heat Shield Replacement: paso 3, imagen 1 de 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Heat Shield Replacement, Heat Shield: paso 4, imagen 1 de 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Heat Shield Replacement: paso 5, imagen 1 de 1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Heat Shield Replacement: paso 6, imagen 1 de 1
    • Your laptop should look approximately like this.
Conclusión
Una persona más ha completado esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,558
