Saltar al contenido principal
PowerA Spectra Contoller D-Pad Replacement
Qué necesitas
  1. PowerA Spectra Contoller D-Pad Replacement, Rear Case: paso 1, imagen 1 de 1
    • Flip the controller over so the backplate is facing up.
  2. PowerA Spectra Contoller D-Pad Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the eight 7.8 mm screws that secure the rear case.
  3. PowerA Spectra Contoller D-Pad Replacement: paso 3, imagen 1 de 1
    • Hold the front case in one hand and pull the rear case off.
  4. PowerA Spectra Contoller D-Pad Replacement, D-Pad: paso 4, imagen 1 de 1
    • Use a Phillips screwdriver to remove the two 7.8 mm screws securing the motherboard to the chassis.
  5. PowerA Spectra Contoller D-Pad Replacement: paso 5, imagen 1 de 1
    • Gently take the motherboard off of the front plate.
  6. PowerA Spectra Contoller D-Pad Replacement: paso 6, imagen 1 de 1
    • Use Phillips screwdriver to remove the four 7.8 mm screws that secure the D-pad.
  7. PowerA Spectra Contoller D-Pad Replacement: paso 7, imagen 1 de 1
    • Gently pry off the D-pad.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 38
