Saltar al contenido principal
PowerA Fusion Controller For Xbox One Motherboard Replacement
Qué necesitas
  1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: paso 1, imagen 1 de 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: paso 1, imagen 2 de 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: paso 1, imagen 3 de 3
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Motherboard Replacement: paso 2, imagen 1 de 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Motherboard Replacement: paso 3, imagen 1 de 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: paso 3, imagen 2 de 2
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
  4. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: paso 4, imagen 1 de 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: paso 4, imagen 2 de 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: paso 4, imagen 3 de 3
    • Remove the five 9.2mm screws with a JIS #1 screwdriver. Indicated by the red circles.
    • Lift the motherboard and let it hang.
  5. PowerA Fusion Controller For Xbox One Motherboard Replacement: paso 5, imagen 1 de 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the four 9.2mm screws that are holding the D-Pad to the controller housing. Indicated by the red circles.
    • Remove the motherboard.
Conclusión
Una persona más ha completado esta guía.
Andrea
Miembro Desde 09/26/17
623 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S14-G4, Boczar Fall 2017 Miembro de USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Miembros
5 Guías creadas
Un comentario
Hi I have a powera fusion controler model CPFA115315-02 and I took the controller apart to clean and I forgot how the lb rb button springs go, I look on the internet and couldn't find anything. Any help would be great
Thanks
Nhgamer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 18
Ultimos 30 días: 42
Todo El Tiempo: 2,954
