Saltar al contenido principal
Porter-Cable PCE211 Fan Replacement
Qué necesitas
  1. Porter-Cable PCE211 Fan Replacement, Gearcase: paso 1, imagen 1 de 2 Porter-Cable PCE211 Fan Replacement, Gearcase: paso 1, imagen 2 de 2
    • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
  2. Porter-Cable PCE211 Fan Replacement: paso 2, imagen 1 de 3 Porter-Cable PCE211 Fan Replacement: paso 2, imagen 2 de 3 Porter-Cable PCE211 Fan Replacement: paso 2, imagen 3 de 3
    • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
    • Be careful about any loose parts when removing the head.
  3. Porter-Cable PCE211 Fan Replacement, Anvil: paso 3, imagen 1 de 3 Porter-Cable PCE211 Fan Replacement, Anvil: paso 3, imagen 2 de 3 Porter-Cable PCE211 Fan Replacement, Anvil: paso 3, imagen 3 de 3
    • Firmly pull the to remove drill bit holder also known as the anvil.
    • Before replacing the anvil, lubricate the base for the best performance.
  4. Porter-Cable PCE211 Fan Replacement, Motor: paso 4, imagen 1 de 3 Porter-Cable PCE211 Fan Replacement, Motor: paso 4, imagen 2 de 3 Porter-Cable PCE211 Fan Replacement, Motor: paso 4, imagen 3 de 3
    • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
    • Pull the motor out with your hands.
  5. Porter-Cable PCE211 Fan Replacement: paso 5, imagen 1 de 3 Porter-Cable PCE211 Fan Replacement: paso 5, imagen 2 de 3 Porter-Cable PCE211 Fan Replacement: paso 5, imagen 3 de 3
    • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
  6. Porter-Cable PCE211 Fan Replacement, Rear Housing: paso 6, imagen 1 de 2 Porter-Cable PCE211 Fan Replacement, Rear Housing: paso 6, imagen 2 de 2
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
  7. Porter-Cable PCE211 Fan Replacement: paso 7, imagen 1 de 2 Porter-Cable PCE211 Fan Replacement: paso 7, imagen 2 de 2
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
  8. Porter-Cable PCE211 Fan Replacement, Grip: paso 8, imagen 1 de 2 Porter-Cable PCE211 Fan Replacement, Grip: paso 8, imagen 2 de 2
    • Using the Phillips #2 screwdriver, remove the three 8 mm screws from the grip of the impact wrench.
  9. Porter-Cable PCE211 Fan Replacement: paso 9, imagen 1 de 2 Porter-Cable PCE211 Fan Replacement: paso 9, imagen 2 de 2
    • Pull the grip from the body of the impact wrench.
  10. Porter-Cable PCE211 Fan Replacement, Fan: paso 10, imagen 1 de 2 Porter-Cable PCE211 Fan Replacement, Fan: paso 10, imagen 2 de 2
    • Lift the hammer block (which is attached to the fan) out of the case.
    • It is a little heavy so be careful when lifting it out.
  11. Porter-Cable PCE211 Fan Replacement: paso 11, imagen 1 de 2 Porter-Cable PCE211 Fan Replacement: paso 11, imagen 2 de 2
    • If you're doing maintenance and the fan isn't damage, use a microfiber cloth to clean the fan.
    • Wipe well until there's no residue or oil lubricant.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 133
