Saltar al contenido principal
Polaroid A10 Speakers Replacement
Qué necesitas
  1. Polaroid A10 Speakers Replacement, Back Cover: paso 1, imagen 1 de 3 Polaroid A10 Speakers Replacement, Back Cover: paso 1, imagen 2 de 3 Polaroid A10 Speakers Replacement, Back Cover: paso 1, imagen 3 de 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Speakers Replacement, Speakers: paso 2, imagen 1 de 1
    • The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
  3. Polaroid A10 Speakers Replacement: paso 3, imagen 1 de 3 Polaroid A10 Speakers Replacement: paso 3, imagen 2 de 3 Polaroid A10 Speakers Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
    • Carefully remove the speakers from original position without pulling out the wires.
  4. Polaroid A10 Speakers Replacement: paso 4, imagen 1 de 1
    • Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
    • The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Speakers Replacement: paso 5, imagen 1 de 1
    • Gently lift the speakers up and out of the device.
Conclusión
Koby
Miembro Desde 01/22/15
104 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 3-3, Rose Winter 2015 Miembro de UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Miembros
12 Guías creadas
3 comentarios
This is not what I meant I wanted to know what to do if the wires came out of the
amirahoresanwo - Contestar
If the wires and out of the
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 239
