Saltar al contenido principal
Polaroid A10 Motherboard Replacement
Qué necesitas
  1. Polaroid A10 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 3 Polaroid A10 Motherboard Replacement, Back Cover: paso 1, imagen 2 de 3 Polaroid A10 Motherboard Replacement, Back Cover: paso 1, imagen 3 de 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Motherboard Replacement, Motherboard: paso 2, imagen 1 de 3 Polaroid A10 Motherboard Replacement, Motherboard: paso 2, imagen 2 de 3 Polaroid A10 Motherboard Replacement, Motherboard: paso 2, imagen 3 de 3
    • Take off yellow tapes that are surrounding the motherboard.
    • Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
  3. Polaroid A10 Motherboard Replacement: paso 3, imagen 1 de 3 Polaroid A10 Motherboard Replacement: paso 3, imagen 2 de 3 Polaroid A10 Motherboard Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #000 screwdriver, remove the four 5 mm screws located in the picture by rotating the screw counter-clockwise.
  4. Polaroid A10 Motherboard Replacement: paso 4, imagen 1 de 2 Polaroid A10 Motherboard Replacement: paso 4, imagen 2 de 2
    • Use the soldering tool to unsolder the two bigger metals from the wires of the battery.
    • Use the same soldering tool to unsolder the four smaller metals from the wires of the speakers.
    • Use the same soldering tool to unsolder the ground wire.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Motherboard Replacement: paso 5, imagen 1 de 3 Polaroid A10 Motherboard Replacement: paso 5, imagen 2 de 3 Polaroid A10 Motherboard Replacement: paso 5, imagen 3 de 3
    • Gently lift the motherboard up and out of the device.
Conclusión
Una persona más ha completado esta guía.
Tracie
Miembro Desde 01/22/15
119 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 3-3, Rose Winter 2015 Miembro de UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 595
