Saltar al contenido principal
Polaroid A10 Battery Replacement
Qué necesitas
  1. Polaroid A10 Battery Replacement, Back Cover: paso 1, imagen 1 de 3 Polaroid A10 Battery Replacement, Back Cover: paso 1, imagen 2 de 3 Polaroid A10 Battery Replacement, Back Cover: paso 1, imagen 3 de 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Battery Replacement, Battery: paso 2, imagen 1 de 3 Polaroid A10 Battery Replacement, Battery: paso 2, imagen 2 de 3 Polaroid A10 Battery Replacement, Battery: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
    • It is better to use a plastic card if you have one.
    • Gently lift up the battery as you continue to separate the glue from the battery.
    • Lift up just enough to see where the glue is, so that you don't bend the battery.
    • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
  3. Polaroid A10 Battery Replacement: paso 3, imagen 1 de 3 Polaroid A10 Battery Replacement: paso 3, imagen 2 de 3 Polaroid A10 Battery Replacement: paso 3, imagen 3 de 3
  4. Polaroid A10 Battery Replacement: paso 4, imagen 1 de 1
    • Gently lift the battery up and out of the device.
Conclusión
Una persona más ha completado esta guía.
armando
Miembro Desde 01/14/15
150 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 3-3, Rose Winter 2015 Miembro de UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 726
