Introducción
This guide will show users how to replace the display (not the glass screen) on the Polar V800 sports watch. If the display has damaged pixels or no longer operates properly, the display may need to be replaced to keep your watch functional.
Qué necesitas
Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
Place a T5 torque screwdriver in the upper right and lower left diagonal 4mm screws that hold the white plastic down and rotate the screwdriver to the left, removing the screws.
4 personas más completaron esta guía.
15 comentarios
Please tell me where can I found spare parts for polar v800 ( motherboard,display)
Thank you
Por sin la encontré. Lleva una Sharp LS013B7DH03
Please tell me where can I found spare parts for polar v800 ( motherboard,display, also the case and waterproof seal )
Thank you
I need to bought a lcd for this watch, someone knows where i can buy it ? Best regards
Same question as above.
