Saltar al contenido principal
PlayStation Vita SIM Card Reader Replacement
Qué necesitas
  1. PlayStation Vita SIM Card Reader Replacement, Case Separation: paso 1, imagen 1 de 2 PlayStation Vita SIM Card Reader Replacement, Case Separation: paso 1, imagen 2 de 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita SIM Card Reader Replacement: paso 2, imagen 1 de 3 PlayStation Vita SIM Card Reader Replacement: paso 2, imagen 2 de 3 PlayStation Vita SIM Card Reader Replacement: paso 2, imagen 3 de 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita SIM Card Reader Replacement: paso 3, imagen 1 de 2 PlayStation Vita SIM Card Reader Replacement: paso 3, imagen 2 de 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita SIM Card Reader Replacement: paso 4, imagen 1 de 3 PlayStation Vita SIM Card Reader Replacement: paso 4, imagen 2 de 3 PlayStation Vita SIM Card Reader Replacement: paso 4, imagen 3 de 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita SIM Card Reader Replacement: paso 5, imagen 1 de 2 PlayStation Vita SIM Card Reader Replacement: paso 5, imagen 2 de 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita SIM Card Reader Replacement: paso 6, imagen 1 de 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita SIM Card Reader Replacement: paso 7, imagen 1 de 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita SIM Card Reader Replacement: paso 8, imagen 1 de 1
    • Separate the front and rear cases.
  9. PlayStation Vita SIM Card Reader Replacement, SIM Card Reader: paso 9, imagen 1 de 2 PlayStation Vita SIM Card Reader Replacement, SIM Card Reader: paso 9, imagen 2 de 2
    • Gently pry open the tab of the flex cable socket on top of the SIM card reader.
    • Free the flex cable by sliding the spudger underneath it and pulling it out of the socket. Rest the flex cable out of the way.
  10. PlayStation Vita SIM Card Reader Replacement: paso 10, imagen 1 de 3 PlayStation Vita SIM Card Reader Replacement: paso 10, imagen 2 de 3 PlayStation Vita SIM Card Reader Replacement: paso 10, imagen 3 de 3
    • Use a spudger to release the plastic tab along the inside of the case and gently pry up the SIM card reader.
  11. PlayStation Vita SIM Card Reader Replacement: paso 11, imagen 1 de 3 PlayStation Vita SIM Card Reader Replacement: paso 11, imagen 2 de 3 PlayStation Vita SIM Card Reader Replacement: paso 11, imagen 3 de 3
    • Lift the SIM card reader out of the casing.
    • Using a Phillips #00 screwdriver, remove the blue, 5.0mm screw from the SIM car reader.
    • Separate the SIM card reader from the SIM card reader retainer.
Conclusión
Una persona más ha completado esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
88,580 Reputación
132 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
136 Miembros
15,118 Guías creadas
Un comentario
I have an error relating to the reader on my Vita. If I took it out without replacing it, will it cause the same or different error so I have to replace it, or will it be (somewhat) fine??
christoffersen366 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 37
Todo El Tiempo: 8,802
