Introducción
This guide takes you through the process of installing the rear panel. The rear panel houses the rear touch pad.
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
Slide the spuder between the right speaker and the rear casing.
Using a spudger, gently peel up the right speaker from the light adhesive connecting it to casing.
Remove the right speaker.
7 personas más completaron esta guía.
3 Comentarios
I really enjoyed Your article ! I'm about to replace the touch pad, i got a Vita recently but it has some Heavy scuffs. I've seen the back touch pad has adhesive attached on it. I bought a replacement On Ebay. I'm not sure if the replacement has adhesive with it. If it doesn't what would be your guys Thoughts on what i should use?
lol you will need some kind of adhesive its called common sense if Sony use it you use it simple
TH3ORY -
