Introducción
If your PlayStation won’t power on, the power supply may need to be replaced. This guide will take you through the process of replacing the power supply.
Note: This repair is demonstrated on a SCPH-1001 model. The process may differ slightly if you have a later model.
Qué necesitas
Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
Pull the power supply cable straight up and out of its socket on the power supply to disconnect it.
Remove the two 14 mm-long Phillips #1 screws securing the power supply to the bottom case.
24 personas más completaron esta guía.
4 comentarios
im done removing the power supply so whats next???btw i accidentally plugged my ps1 110v to 220v how to fix that issue???
Before anything unplug your PlayStation and try the power button couple a times to turn on the PlayStation.
Just check the fuse with a multimeter. It is a cylindrical tube with metal on it’s two corners. The easy way is to check continuity with a mutimeter which is a symbol with a speaker on it. Touch red and black probes and you will hear a beep. Connect the two ends of the fuse and if it beeps then fuse is ok. You can even check it while fuse is on the board. If ok and PlayStation is not working then there is a problem somewhere else on the power board, mostly…
Good Luck!!
gUru0026 -
