Saltar al contenido principal
PlayStation Move Battery Replacement
Qué necesitas
  1. PlayStation Move  Battery Replacement, Battery: paso 1, imagen 1 de 3 PlayStation Move  Battery Replacement, Battery: paso 1, imagen 2 de 3 PlayStation Move  Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
  2. PlayStation Move  Battery Replacement: paso 2, imagen 1 de 2 PlayStation Move  Battery Replacement: paso 2, imagen 2 de 2
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
  3. PlayStation Move  Battery Replacement: paso 3, imagen 1 de 2 PlayStation Move  Battery Replacement: paso 3, imagen 2 de 2
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
  4. PlayStation Move  Battery Replacement: paso 4, imagen 1 de 3 PlayStation Move  Battery Replacement: paso 4, imagen 2 de 3 PlayStation Move  Battery Replacement: paso 4, imagen 3 de 3
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  5. PlayStation Move  Battery Replacement: paso 5, imagen 1 de 2 PlayStation Move  Battery Replacement: paso 5, imagen 2 de 2
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  6. PlayStation Move  Battery Replacement: paso 6, imagen 1 de 2 PlayStation Move  Battery Replacement: paso 6, imagen 2 de 2
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  7. PlayStation Move  Battery Replacement: paso 7, imagen 1 de 3 PlayStation Move  Battery Replacement: paso 7, imagen 2 de 3 PlayStation Move  Battery Replacement: paso 7, imagen 3 de 3
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  8. PlayStation Move  Battery Replacement: paso 8, imagen 1 de 2 PlayStation Move  Battery Replacement: paso 8, imagen 2 de 2
    • Gently pull on the white piece connecting the battery and the connector.
Conclusión
8 personas más completaron esta guía.
Equipo
USF Tampa, Team 3-3, Passmore Fall 2016 Miembro de USF Tampa, Team 3-3, Passmore Fall 2016
USFT-PASSMORE-F16S3G3
4 Miembros
8 Guías creadas
4 comentarios
When putting the plastic battery rig back in on my second time doing this, I bent one of the little plastic pins that fits into a hole in the PCB. Definitely want to be careful with that. To make it a bit easier, I unscrewed the bottom port PCB part of the way so I could take the bottom plastic housing and put the plastic battery rig in straight. It made it a lot easier.
Burke Cates - Contestar
No need to take out the motor, just use sharp tweezers and grab the connector (NOT the wires) and with small wiggling pull it out. Worked for mine.
crus - Contestar
Worked great! Thanks for this. I did not need to take out the black battery / motor piece. Tweezers worked great to remove and install the battery cable
Harry Skigis - Contestar
Any recommended online / physical store to buy new batteries for this because ifixit doesn’t have them?
Silas Stewart - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 18
Ultimos 30 días: 76
Todo El Tiempo: 14,246
