Saltar al contenido principal
Introducción
This guide will show the steps necessary to replace the heat pipe in the PS4 Pro. This process involves warranty-voiding disassembly and many steps. The heat pipe is located halfway between the top and bottom of the PS4 Pro, and thus requires components from both sides to be removed in order to replace.
  1. Flip the console upside down. Use your finger to pull and snap off the plastic cover over the hard drive. Use your finger to pull and snap off the plastic cover over the hard drive.
    • Flip the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
  2. Use a Phillips #0 Screwdriver to remove the single screw securing the hard drive caddy. Pull the hard drive caddy straight out.
    • Use a Phillips #0 Screwdriver to remove the single screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
  3. Flip the console right side up. Grip the two corners located at the front of the device. Pull upwards until a loud click is heard.
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
  4. Use a T8 Torx Security screwdriver to remove five screws from the rear of the device. Two 31mm screws. Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
    • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
    • Two 31mm screws.
    • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
    • Remove the metal plate by pulling it up.
  5. Flip the console over so the bottom is facing up. Use a T8 Torx Security  screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left. Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
    • Flip the console over so the bottom is facing up.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
    • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
  6. Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate. Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate. Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
    • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
    • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
    • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
  7. Pull the white fan connector straight out of the yellow mount on the motherboard. Pull the white fan connector straight out of the yellow mount on the motherboard.
    • Pull the white fan connector straight out of the yellow mount on the motherboard.
  8. Pull out the five small, blue low profile cables connected to the metal plate. Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull out the five small, blue low profile cables connected to the metal plate.
    • Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull the large ribbon cable from its socket.
    • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
  9. Pull up and remove the metal plate.
    • Pull up and remove the metal plate.
  10. Flip the console over to continue working on the top side. Pull up on the power supply unit and set it on the console. Be careful not to pull too far, the assembly is still connected at one point.
    • Flip the console over to continue working on the top side.
    • Pull up on the power supply unit and set it on the console.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
  11. Carefully flip the console over so the bottom is facing up. Use a Phillips #1 screwdriver to remove the eight 4mm screws on the metal plate with the X-like symbol. Use a plastic opening tool to remove the metal plate with the X-like shape.
    • Carefully flip the console over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the eight 4mm screws on the metal plate with the X-like symbol.
    • Use a plastic opening tool to remove the metal plate with the X-like shape.
  12. Use a Phillips #1 screwdriver to remove the four 13mm screws on the X-shaped metal plate underneath. Grip the X-shaped retaining bracket and lift straight up. Grip the X-shaped retaining bracket and lift straight up.
    • Use a Phillips #1 screwdriver to remove the four 13mm screws on the X-shaped metal plate underneath.
    • Grip the X-shaped retaining bracket and lift straight up.
  13. Grip the edge of the motherboard and slowly lift upwards to remove it from the device. For reassembly,  use this guide to reapply thermal paste between the motherboard and the metal plate underneath.
    • Grip the edge of the motherboard and slowly lift upwards to remove it from the device.
    • For reassembly, use this guide to reapply thermal paste between the motherboard and the metal plate underneath.
  14. Use a Phillips #0 screwdriver to remove the two 6 mm silver screws from the metal plate. Use a Phillips #0 screwdriver to remove the two 6 mm silver screws from the metal plate.
    • Use a Phillips #0 screwdriver to remove the two 6 mm silver screws from the metal plate.
  15. Lift the metal plate that is connected to the heat pipe straight up to remove it. Lift the metal plate that is connected to the heat pipe straight up to remove it.
    • Lift the metal plate that is connected to the heat pipe straight up to remove it.
Conclusión
25 personas más completaron esta guía.
Thomas
Miembro Desde 26/04/17
2,653 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S21-G5, Livingston Spring 2017 Miembro de Cal Poly, Team S21-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G5
4 Miembros
39 Guías creadas
2 comentarios
Ist es schlimm, wenn man die 2 schrauben von schritt 14 vergessen hat zum verschrauben?
AxoN z - Contestar
Can anyone explain what are those 5 blocks near heatsink as mine are broken when I open it 2 blocks have converted into dust plz help
rajatagg41 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 47
Ultimos 7 días: 268
Ultimos 30 días: 1,022
Todo El Tiempo: 35,272
