Introducción
This guide will teach you how to replace the motor and will require some soldering.
Qué necesitas
Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
Use the tweezers to pull out the inner power button.
4 personas más completaron esta guía.
4 comentarios
¿Me puedes ayudar con algo?
Can you help me with something?
this guide was created also by nina lovekrist in 2015
Where can I get the motor with copper shaft?
