Introducción
Use this guide to remove and replace a damaged battery cover on the Pentax Optio WG-2.
Qué necesitas
Paso 1 Back Case
Aviso: los pasos 1-6 provienen de una guía que está marcada como "En progreso".
Remove all four 1 mm JIS #00 screws from the back of the camera.
Lift the cover as you normally would if replacing battery.
Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
Casi Terminas!
Conclusión
