Saltar al contenido principal
Pentax Optio WG-2 Battery Compartment Door Replacement
Qué necesitas
  1. Aviso: los pasos 1-6 provienen de una guía que está marcada como "En progreso".
    Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: paso 1, imagen 1 de 2 Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: paso 1, imagen 2 de 2
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 Battery Compartment Door Replacement: paso 2, imagen 1 de 1
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 Battery Compartment Door Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 Battery Compartment Door Replacement: paso 4, imagen 1 de 3 Pentax Optio WG-2 Battery Compartment Door Replacement: paso 4, imagen 2 de 3 Pentax Optio WG-2 Battery Compartment Door Replacement: paso 4, imagen 3 de 3
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 Battery Compartment Door Replacement: paso 5, imagen 1 de 1
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 Battery Compartment Door Replacement: paso 6, imagen 1 de 1
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: paso 7, imagen 1 de 3 Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: paso 7, imagen 2 de 3 Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: paso 7, imagen 3 de 3
    • Lift the cover as you normally would if replacing battery.
    • Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
    • There is a pin (3/4 of an inch long) that attaches the cover to the camera and it will come loose when the cover is removed.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 772
