Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
You will be taking the wheel off of your bike, removing the tire from the wheel, and patching the hole.
Notes:
  • Make sure that the wheel is fully deflated throughout the process, except for finding the hole.
  • When applying the rubber cement to the hole, the thinner the layer the better, for faster drying.
  1. Flip the quick release lever on the wheel. Flip the quick release lever on the wheel.
    • Flip the quick release lever on the wheel.
  2. Squeeze the brake arms together and lift the brake cable from the caliper arms.
    • Squeeze the brake arms together and lift the brake cable from the caliper arms.
  3. Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
    • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  4. Press the valve core while applying pressure to the tire to deflate the tire.
    • Press the valve core while applying pressure to the tire to deflate the tire.
  5. Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel. Slide the lever around the circumference of the wheel to completely remove the tire.
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  6. Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  7. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  8. Press the valve core while applying pressure to the tire to deflate the tire.
  9. Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel. Slide the lever around the circumference of the wheel to completely remove the tire.
  10. Remove the tube by pushing the valve through the hole in the rim and pulling out completely.
    • Remove the tube by pushing the valve through the hole in the rim and pulling out completely.
  11. Locate the leak by first over inflating the tire. Place the tire under water and look for bubbles to find the leak.
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  12. Mark the hole with a marker, and completely deflate the tire.
    • Mark the hole with a marker, and completely deflate the tire.
  13. Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  14. Clean the area near the hole with soap and water, then dry it thoroughly.
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  15. Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  16. Apply the patch to the area.
    • Apply the patch to the area.
  17. Apply pressure to the patch until the rubber cement is dry.
    • Apply pressure to the patch until the rubber cement is dry.
Conclusión
To reassemble your wheel, follow these instructions in reverse order starting at step three.
6 personas más completaron esta guía.
Travis Tonder
Miembro Desde 05/10/10
2,607 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 5-13, Maness Fall 2010 Miembro de Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 3,919
