Introducción
In this guide, the USB port will be replaced on the Parrot Skycontroller 2P. If you are having trouble, with your phone connecting to the device, the USB port could be the problem. This guide will require desoldering and soldering the port, so check out our How to Solder and Desolder Connections guide for help on how to do so.
Before beginning, make sure to power off your device completely and disconnect from any external power source.
Qué necesitas
Remove the seven black 11mm screws using the Torx TR6 screwdriver.
Pull back the sticker with your finger nail and remove one 11mm screws using the Torx TR6 screwdriver.
