Saltar al contenido principal
Panasonic Lumix ZS50 Flash Assembly Replacement
Qué necesitas
  1. Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: paso 1, imagen 1 de 2 Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Flash Assembly Replacement: paso 2, imagen 1 de 2 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 2, imagen 2 de 2
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Flash Assembly Replacement: paso 3, imagen 1 de 1
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Flash Assembly Replacement: paso 4, imagen 1 de 1
    • The battery should now be released; you may now remove the battery from the camera body.
  5. Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: paso 5, imagen 1 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: paso 5, imagen 2 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: paso 5, imagen 3 de 3
    • Orient the camera so the bottom is facing up and the battery door is on the right side.
    • Remove four black screws from the bottom of the camera.
    • Remove two black screws from the right side of the camera.
    • Remove one black screw from the left side of the camera.
  6. Panasonic Lumix ZS50 Flash Assembly Replacement: paso 6, imagen 1 de 2 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 6, imagen 2 de 2
    • Remove the casing from the camera by hand or using a plastic opening tool.
  7. Panasonic Lumix ZS50 Flash Assembly Replacement: paso 7, imagen 1 de 2 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 7, imagen 2 de 2
    • Use a spudger to lift up and tug off the green button board.
    • Be careful to not damage the attached ribbon cable.
  8. Panasonic Lumix ZS50 Flash Assembly Replacement: paso 8, imagen 1 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 8, imagen 2 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 8, imagen 3 de 3
    • Remove the screen using the plastic opening tool, prying from the top.
    • Once it's lifted up, tug lightly on the large ribbon cable to detach the screen from the camera body.
  9. Aviso: los pasos 9-12 provienen de una guía que está marcada como "En progreso".
    Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: paso 9, imagen 1 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: paso 9, imagen 2 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: paso 9, imagen 3 de 3
    • Remove the three screws from the center of the copper plate.
    • Remove the four screws from the outer edges of the copper plate.
    • Use a plastic or metal spudger to pry the copper plate out of place.
  10. Panasonic Lumix ZS50 Flash Assembly Replacement: paso 10, imagen 1 de 2 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 10, imagen 2 de 2
    • Remove the casing from the circuitboard by hand.
    • Remove the HDMI port casing by hand.
  11. Panasonic Lumix ZS50 Flash Assembly Replacement: paso 11, imagen 1 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 11, imagen 2 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 11, imagen 3 de 3
    • Disconnect all orange ribbon cables connecting to the circuitboard by hand.
    • Disconnect the circuitboard by hand.
    • There will be one orange ribbon cable attached to the top that can now be removed.
  12. Panasonic Lumix ZS50 Flash Assembly Replacement: paso 12, imagen 1 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 12, imagen 2 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 12, imagen 3 de 3
    • Remove the seven screws surrounding the lens assembly.
    • Move all ribbon cables out of your way while unscrewing.
    • Remove the three springs surrounding the lens.
    • Apply pressure on the front of the lens to push the lens out.
  13. Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: paso 13, imagen 1 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: paso 13, imagen 2 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: paso 13, imagen 3 de 3
    • Remove the one screw holding the camera and the flash component together.
    • Gently pull the flash component out of the camera body.
  14. Panasonic Lumix ZS50 Flash Assembly Replacement: paso 14, imagen 1 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 14, imagen 2 de 3 Panasonic Lumix ZS50 Flash Assembly Replacement: paso 14, imagen 3 de 3
    • Separate the top camera casing from the flash component by unscrewing the three surrounding screws.
    • Remove the flash assembly, including the circuit board, by detaching it and the ribbon cables from the casing.
Conclusión
Una persona más ha completado esta guía.
Equipo
Baylor, Team 8-5, Whitney Spring 2017 Miembro de Baylor, Team 8-5, Whitney Spring 2017
BU-WHITNEY-S17S8G5
3 Miembros
4 Guías creadas
Un comentario
Step 7: Does not mention the HDMI port door. Make sure you account for it
BayleeVersteeg - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 215
