Qué necesitas
Turn the camera off and identify the battery door located on the bottom of the camera.
Orient the camera so the bottom is facing up and the battery door is on the right side.
Remove four black screws from the bottom of the camera.
Remove two black screws from the right side of the camera.
Remove one black screw from the left side of the camera.
Remove the three screws from the center of the copper plate.
Remove the four screws from the outer edges of the copper plate.
Use a plastic or metal spudger to pry the copper plate out of place.
