Saltar al contenido principal
Panasonic Lumix DMC-GH3 Disassembly
Qué necesitas
  1. Panasonic Lumix DMC-GH3 Disassembly, Panasonic Lumix DMC-GH3 Disassembly: paso 1, imagen 1 de 2 Panasonic Lumix DMC-GH3 Disassembly, Panasonic Lumix DMC-GH3 Disassembly: paso 1, imagen 2 de 2
    • To start the disassembly, place the camera with the lens side down and the back facing you. This camera is assembled in planar layers, so it is best to start from the back.
    • Begin by removing the eyepiece rubber. Slide this part up and it will reveal 5 screws. Remove all of them. Be careful to keep track of the order of these screws and the thread type. Use tape to keep track of the screws.
    • You will need a JIS0 and JIS00 screwdriver and a plastic spudger for this disassembly.
  2. Panasonic Lumix DMC-GH3 Disassembly: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Mako Driver Kit - 64 Precision Bits
    $39.95
    Comprar
    • It's important to recognize that this is a camera produced by a Japanese camera manufacturer. The Japanese camera industry loves using JIS (Japanese Industrial Standard) screws over traditional Phillips screws.
    • Although PH#00 will interchange with JIS#00, it is not a perfect fit. Using Phillips can cause more wear on the head of the JIS screws and cause the screws to prematurely strip. If you are in a pinch, just go ahead and use Phillips.
    • Have both JIS#00 and JIS#000 screw drivers available for this teardown. Luckily, both bits are included in the ifixit 64bit kit.
  3. Panasonic Lumix DMC-GH3 Disassembly: paso 3, imagen 1 de 2 Panasonic Lumix DMC-GH3 Disassembly: paso 3, imagen 2 de 2
    • Remove the 3 screws on the right hand side.
  4. Panasonic Lumix DMC-GH3 Disassembly: paso 4, imagen 1 de 2 Panasonic Lumix DMC-GH3 Disassembly: paso 4, imagen 2 de 2
    • Remove the three screws on the left hand side of the camera.
  5. Panasonic Lumix DMC-GH3 Disassembly: paso 5, imagen 1 de 2 Panasonic Lumix DMC-GH3 Disassembly: paso 5, imagen 2 de 2
    • There are 6 screws on the bottom of the camera. One is hidden in the battery compartment.
  6. Panasonic Lumix DMC-GH3 Disassembly: paso 6, imagen 1 de 1
    • This screw is a bit of a pain to remove as it requires a long shaft screw driver.
    • From here on in, it is strongly recommended to use tape to keep track of the screws as you disassemble the camera. Screws are not always uniform in length or thread type, and some are aluminum, so tape works best here.
  7. Panasonic Lumix DMC-GH3 Disassembly: paso 7, imagen 1 de 2 Panasonic Lumix DMC-GH3 Disassembly: paso 7, imagen 2 de 2
    • The rear shell of the camera should now be free to slide off the rest of the camera body.
    • Rock the rear shell of the camera from left side to the right side to aid in the removal of the rear LCD shell assembly.
  8. Panasonic Lumix DMC-GH3 Disassembly: paso 8, imagen 1 de 1
    • Once the electronics are exposed, it is highly recommended that you remain ESD safe. ESD can fry your precious electronics, and pass thousands of volts through components only rated for a few V DC. ESD can sure ruin your day if you are not careful.
    • Use an ESD mat and wrist strap, and make sure you are grounded for the remaining of the teardown. Make sure your ESD mat is connected to the ground of a nearby outlet, and make sure your house actually has a ground. Consult an electrician if you are unsure.
  9. Panasonic Lumix DMC-GH3 Disassembly: paso 9, imagen 1 de 2 Panasonic Lumix DMC-GH3 Disassembly: paso 9, imagen 2 de 2
    • The rear LCD shell can be rotated away from the rest of the shell like a hinge.
    • Be careful not to pull too hard on the ribbon cables!
    • The back LCD and button assembly attached to the main PCB through 2 ribbon cables.
    • Use a plastic spudger to remove the ribbon cables from the LCD ribbon connectors.
  10. Panasonic Lumix DMC-GH3 Disassembly: paso 10, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 10, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 10, imagen 3 de 3
    • This is the rear shell assembly of the GH3. This contains the LCD sub-assembly buttons and switches.
    • To remove the LCD hinge covers, remove the two screws circled on the right.
    • The hinge covers will simply drop out from the other side.
  11. Panasonic Lumix DMC-GH3 Disassembly: paso 11, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 11, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 11, imagen 3 de 3
    • Here's what the rear shell looks like without the LCD hinge covers.
    • To get further access to the LCD, Remove the 4 screws holding on the plastic cover to the back of the unit.
    • This reveals the ribbon cables from the LCD.
  12. Panasonic Lumix DMC-GH3 Disassembly: paso 12, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 12, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 12, imagen 3 de 3
    • To remove the left side buttons, remove the 10 screws holding in the button panel.
  13. Panasonic Lumix DMC-GH3 Disassembly: paso 13, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 13, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 13, imagen 3 de 3
    • To get further access to the LCD, remove the 2 circled screws.
    • Now the LCD is free from the rear shell. Just be careful snaking the ribbon cables through the shell.
  14. Panasonic Lumix DMC-GH3 Disassembly: paso 14, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 14, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 14, imagen 3 de 3
    • Back to the rest of the camera. With the back LCD shell assembly removed from the body of the camera, It's time to remove the main PCB.
    • Remove the 5 circled screws. There is a back plastic cover that protects the battery PCB terminals. That should come free once these screws are removed.
  15. Panasonic Lumix DMC-GH3 Disassembly: paso 15, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 15, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 15, imagen 3 de 3
    • With the cover removed, go ahead and begin removing all the ribbon cables from the PCB. Remove the 2 pin connector as well.
    • There is one more screw holding in the PCB. Remove the screw on the left hand side of the camera which holds the I/O cover to the PCB.
    • The PCB should now be relatively lose inside the camera.
  16. Panasonic Lumix DMC-GH3 Disassembly: paso 16, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 16, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 16, imagen 3 de 3
    • There are 2 black plastic tabs that hold in the PCB. Use a plastic spudger to depress the tabs.
    • The PCB should now come out freely.
  17. Panasonic Lumix DMC-GH3 Disassembly: paso 17, imagen 1 de 1
    • The next part of the disassembly involves the removal of the top assembly.
    • The removal of the top assembly requires you to remove the screws under the pop-up flash unit.
  18. Panasonic Lumix DMC-GH3 Disassembly: paso 18, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 18, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 18, imagen 3 de 3
    • Since the camera is powered off and the battery is removed, the electronically controlled pop-up flash is non-operational. Thus, continuing the repair a bit of a hassle as getting to the two screws is impossible.
    • This means you would have to pop-up the flash before starting the entire diassembly process! This is rather silly, because the pop-up flash gets in the way when disassembling the rest of the camera and it is a delicate assembly.
    • I discovered an easy solution. Take a piece of blue tape, fold it over and shove it between the flash assembly and the shell of the camera.
  19. Panasonic Lumix DMC-GH3 Disassembly: paso 19, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 19, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 19, imagen 3 de 3
    • Take this doubled over piece of tape and forcefully shove it toward the back of the flash camera unit. This will trigger the pop-up flash latch release inside the camera and allow you to continue the disassembly without ever needing power!
    • Those two little screws are the culprit! The funny thing is the previous camera, the Lumix GH2, also featured screws here, but the pop-up flash had a manual switch! I guess the designers forgot about this when they implemented an electronic flash trigger switch.
  20. Panasonic Lumix DMC-GH3 Disassembly: paso 20, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 20, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 20, imagen 3 de 3
    • You will need a long shaft JIS screwdriver here too! I didn't have one long enough, so I cheated and used a Phillips to remove these two screws
    • Remove the two screws from the front face of the camera as well.
    • Remove the one screw holding in the aluminum heatsink to the remainder of the camera.
  21. Panasonic Lumix DMC-GH3 Disassembly: paso 21, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 21, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 21, imagen 3 de 3
    • The heatsink is held in on the right hand side by two small clips. Use the spudger fo un-clip the heatsink from the camera.
    • With the heatsink removed, the sensor block assembly is uncovered and the battery compartment is finally unobstructed.
    • Remove the circled screw from the battery compartment. This screw secures the front grip of the camera to the camera shell.
  22. Panasonic Lumix DMC-GH3 Disassembly: paso 22, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 22, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 22, imagen 3 de 3
    • The grip should now be free and come off the camera easily.
    • Panasonic hid the wifi unit under the grip. This is quite clever since the grip is entirely plastic and electromagnetic waves have little trouble passing through plastic. If they buried the antenna unit further inside the camera, the performance would be greatly hindered by the other metal shelled components.
    • The top unit should now be loose and come free from the camera.
  23. Panasonic Lumix DMC-GH3 Disassembly: paso 23, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 23, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 23, imagen 3 de 3
    • The top unit should be held on only by the flash unit cable. Disconnect this cable and the top unit is now free.
    • If your workbench is a mess at this point you're heading in the right direction!
  24. Panasonic Lumix DMC-GH3 Disassembly: paso 24, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 24, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 24, imagen 3 de 3
    • The sensor block assembly, front shell and battery compartment are all that's left of this camera.
    • Let's start with the battery compartment. Remove the two circled screws.
    • The battery compartment should just slide up and out of the camera shell.
  25. Panasonic Lumix DMC-GH3 Disassembly: paso 25, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 25, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 25, imagen 3 de 3
    • Before removing the sensor block assembly, the sub frame assembly must be removed.
    • Remove the two screws circled. This will provide full access to the sensor block assembly mount screws.
  26. Panasonic Lumix DMC-GH3 Disassembly: paso 26, imagen 1 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 26, imagen 2 de 3 Panasonic Lumix DMC-GH3 Disassembly: paso 26, imagen 3 de 3
    • This is the most important step in the entire repair disassembly process. This is the sensor block unit. Do not touch any part of this assembly other than the screw mount flanges on the magnesium machined assembly. In this case, I bent up the sensor ribbon cable lightly. I didn't touch any surface or place additional force on any sensor block part.
    • Placing pressure on any part of this unit will change the sensor characteristic and and will require re-calibration and reprogramming of the sensor EEPROM. The tools for reprogramming the sensor calibration EEPROM are not publicly available to my knowledge.
    • It is important to only unscrew the purple-tinted screws which are circled. Do not adjust or touch the spring loaded screws on the sensor block. These screws are adjusted at time of sensor calibration in the Panasonic assembly and testing factory.
    • The plane of the sensor is calibrated to the plane of the lens elements or lens mount. Adjusting the tension on any sensor box mount screw makes the sensor and elements out of orthogonal alignment.
    • That's it! Remember to keep track of those screws!
Conclusión
3 personas más completaron esta guía.
Anthony Kouttron
Miembro Desde 02/24/17
5,498 Reputación
5 Guías creadas
Equipo
salvagedcircuitry Miembro de salvagedcircuitry
Business
1 Miembro
7 Guías creadas
4 comentarios
Very thorough and detailed with lots of needed cautions. I will not attempt this on my GH5 to replace or repair a broken function control knob on my own. This way I have a sense of time needed for a repair and the probable cost be a pro. All for a cheap plastic part they broke off from a minor bump.
merlecole - Contestar
Hi merlecole , The GH5 is a similarly disassembly, but the control knob is a relatively straight forward repair. All you need to do is remove the back shell of the camera. You would need to remove the two back ribbon connectors from the front half of the camera which are attached to the main PCB, but that’s the only mildly challenging part. Once the back half is safely removed, its smooth sailing from there. Good luck!
Anthony Kouttron -
Hi Anthony, very good disassembly instructions thanks. My GH3 has only one problem. The knurled thumbwheel to the right of the viewfinder turns but the switching or potentiometer drags as if grease in it has hardened, or an override clutch has weakened. Do you know if this is a common issue with these? Does repairing it involve a serious stripdown? If so I'm prepared to do it. Best wishes, Tim.
tim.gillett - Contestar
Hi! This is a very easy problem to repair. A lot of gh3 / gh4 control dials skip over time from the friction fit of the rubber dial and the rotating inner plastic dial loosening over time. This is normal because rubber changes over time. In this case, you just need to place a droplet of super glue between the inside of the rubber dial and the rotating plastic groove it sits in. You don't even need to dissemble the camera to repair it. Use your thumb and push the rubber on the dial up to dislodge it from the groove it sits in. You will see a c-channel shaped grove. This is where you want to put the super glue. Grab a sewing needle or pin and a tube of superglue from the store. Any superglue will work. The key is, use a small amount! Squeeze the super glue applicator bottle until a droplet forms on the needle tip. Place this droplet in the c-channel groove I mentioned above. Using a small amount will not overflow the groove so when you push back the rubber part, no glue will spill over and ruin the dial. I have a video of this process I will post soon, probably to youtube.
Anthony Kouttron -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 45
Todo El Tiempo: 4,650
