Saltar al contenido principal
Panasonic KX-TGE233 TEL Port Replacement
Qué necesitas
  1. Panasonic KX-TGE233 TEL Port Replacement, Base Front Panel Assembly: paso 1, imagen 1 de 1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 TEL Port Replacement: paso 2, imagen 1 de 1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 TEL Port Replacement: paso 3, imagen 1 de 1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 TEL Port Replacement: paso 4, imagen 1 de 1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 TEL Port Replacement: paso 5, imagen 1 de 1
    • With the back removed, we now have direct access to all other components in the main docking station.
  6. Panasonic KX-TGE233 TEL Port Replacement, TEL Port: paso 6, imagen 1 de 1
    • For easier access to its wires, you can easily remove the TEL port from its resting point in the device.
  7. Panasonic KX-TGE233 TEL Port Replacement: paso 7, imagen 1 de 1
  8. Panasonic KX-TGE233 TEL Port Replacement: paso 8, imagen 1 de 1
    • From here, you can remove the faulty port from the device. If the soldering step has been completed successfully, this should require minimal effort.
Conclusión
Equipo
IUPUI, Team 2-2, Baechle Spring 2016 Miembro de IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 473
