Introducción
One the back cover has been removed from the phone, 4 black clips will be popped off to reveal the antenna. Then it pops off.
Herramientas
Partes
No se especificaron partes.
Press the button on the back cover to release the battery cover.
Slide off the battery cover.
Remove the stylus by pulling up on the large top to reveal the top left case screw.
Pull away the black flap to reveal the top right case screw.
Use the T5 screwdriver attachment to remove the 5 black back case screws marked by the red and yellow circles. These screws are 0.274 inches long.
Use the same T5 screwdriver attachment to remove the middle screw marked by the blue circle. It is shorter than the other screws at 0.121 inches in length.
The antenna is on the back half of the phone, and is marked by the yellow square.
