Saltar al contenido principal
Ozeri Pronto ZK14-S LCD Replacement
Qué necesitas
  1. Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: paso 1, imagen 1 de 2 Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: paso 1, imagen 2 de 2
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S LCD Replacement: paso 2, imagen 1 de 1
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S LCD Replacement: paso 3, imagen 1 de 1
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S LCD Replacement: paso 4, imagen 1 de 2 Ozeri Pronto ZK14-S LCD Replacement: paso 4, imagen 2 de 2
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S LCD Replacement: paso 5, imagen 1 de 2 Ozeri Pronto ZK14-S LCD Replacement: paso 5, imagen 2 de 2
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S LCD Replacement: paso 6, imagen 1 de 1
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S LCD Replacement: paso 7, imagen 1 de 1
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S LCD Replacement: paso 8, imagen 1 de 1
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S LCD Replacement: paso 9, imagen 1 de 2 Ozeri Pronto ZK14-S LCD Replacement: paso 9, imagen 2 de 2
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
  10. Ozeri Pronto ZK14-S LCD Replacement, LCD: paso 10, imagen 1 de 2 Ozeri Pronto ZK14-S LCD Replacement, LCD: paso 10, imagen 2 de 2
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
    • Using the 2.0 Flathead screwdriver, remove the three 7.20 mm screw on the back of the center LCD motherboard.
  11. Ozeri Pronto ZK14-S LCD Replacement: paso 11, imagen 1 de 3 Ozeri Pronto ZK14-S LCD Replacement: paso 11, imagen 2 de 3 Ozeri Pronto ZK14-S LCD Replacement: paso 11, imagen 3 de 3
    • Stand the center motherboard up to expose the LCD screen
    • Be careful when standing up the LCD motherboard to avoid damaging the wires it is connected to.
    • Remove the LCD screen.
Conclusión
3 personas más completaron esta guía.
Oneika White
Miembro Desde 10/01/15
709 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 1-4, Leahy Fall 2015 Miembro de USF Tampa, Team 1-4, Leahy Fall 2015
USFT-LEAHY-F15S1G4
4 Miembros
5 Guías creadas
Un comentario
I had a similar model, it was different to open but the LCD was showing all 8's, I just reset the same LCD and it worked like new.
Dennis Lima - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 560
