Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu iPhone 1st Generation Dock, utiliza nuestros manuales de servicio .
  1. Original iPhone Dock Teardown, Original iPhone Dock Teardown: paso 1, imagen 1 de 3 Original iPhone Dock Teardown, Original iPhone Dock Teardown: paso 1, imagen 2 de 3 Original iPhone Dock Teardown, Original iPhone Dock Teardown: paso 1, imagen 3 de 3
    • The Original iPhone dock!
    • This dock only holds the original iPhone. It will not hold the iPhone 3G/3GS as it is wider and thicker.
  2. Original iPhone Dock Teardown: paso 2, imagen 1 de 3 Original iPhone Dock Teardown: paso 2, imagen 2 de 3 Original iPhone Dock Teardown: paso 2, imagen 3 de 3
    • Use a hair dryer or heat gun to weaken the adhesive holding the rubber foot to the dock.
    • Use a razor blade or flathead screwdriver to pull up part of the rubber foot.
    • While still hot, pull the rubber foot off the dock.
  3. Original iPhone Dock Teardown: paso 3, imagen 1 de 2 Original iPhone Dock Teardown: paso 3, imagen 2 de 2
    • Using a spudger or a flat head screwdriver, release the 6 clips holding the dock to the white plastic molding.
    • You will need to pry this out as the dock contains a weight that is stuck to the top casing with adhesive.
  4. Original iPhone Dock Teardown: paso 4, imagen 1 de 1
    • Heat up the adhesive that covers the three screws, so you can unscrew the screws that hold the weight in the base of the dock.
  5. Original iPhone Dock Teardown: paso 5, imagen 1 de 3 Original iPhone Dock Teardown: paso 5, imagen 2 de 3 Original iPhone Dock Teardown: paso 5, imagen 3 de 3
    • Remove the three screws holding the weight to the bottom plate.
  6. Original iPhone Dock Teardown: paso 6, imagen 1 de 1
    • The dock should look like this.
    • If not, go back and see what you did wrong.
  7. Original iPhone Dock Teardown: paso 7, imagen 1 de 1
    • Now remove the green logic board from the little plastic pegs on the bottom plate.
    • There is one peg under each black foam padding.
  8. Original iPhone Dock Teardown: paso 8, imagen 1 de 2 Original iPhone Dock Teardown: paso 8, imagen 2 de 2
    • The little white things are the pegs.
    • Gently use a spudger or flathead screwdriver to pry the logic board from the bottom plate.
    • Be very careful, as you could break the board doing this.
  9. Original iPhone Dock Teardown: paso 9, imagen 1 de 2 Original iPhone Dock Teardown: paso 9, imagen 2 de 2
    • Once done separating the logic board from the bottom plate, you should have 2 parts.
  10. Original iPhone Dock Teardown: paso 10, imagen 1 de 3 Original iPhone Dock Teardown: paso 10, imagen 2 de 3 Original iPhone Dock Teardown: paso 10, imagen 3 de 3
    • Disassembly is now complete. You will have five separate parts as shown in the picture.
  11. Original iPhone Dock Teardown: paso 11, imagen 1 de 3 Original iPhone Dock Teardown: paso 11, imagen 2 de 3 Original iPhone Dock Teardown: paso 11, imagen 3 de 3
    • Boom! Your done. It took me 32 minutes to figure this out with out damaging the dock.
    • I can do it in 3 minutes now that I've mastered the process.
    • If you don't replace the white top cover of the dock when reassembling, you will have a universal dock, that can also be used with an iPhone 3G/3GS.
    • It will also work with any iPod with a 30 pin connector.
Nicholas Ouimet
Miembro Desde 10/16/09
3,479 Reputación
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 48
Todo El Tiempo: 32,918
