Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Using a spudger or a flat head screwdriver, release the 6 clips holding the dock to the white plastic molding. You will need to pry this out as the dock contains a weight that is stuck to the top casing with adhesive.
  • Using a spudger or a flat head screwdriver, release the 6 clips holding the dock to the white plastic molding.
  • You will need to pry this out as the dock contains a weight that is stuck to the top casing with adhesive.
Insertar traducción aquí
